Hi all,
Basically the last few bits of my new build arrived this morning, first here's a run down of my setup:
mobo: MSI GD-80 P55
cpu: Core I5 760
ram: OCZ Reaper 1600mhz
GFX: Powercolour 4890
PSU: OCZ modxstream 600w
SSD: Crucial C300 128GB
Controller Card: Highpoint rocket620
Sound Card: ASUS Xonar DG
I installed everything, plugged the rocket into my PCI-E x1 slot above my gfx card and installed w7 onto the ssd.
I decided to run Crystal mark to test my ssd's speeds and there was a problem - my reads weren't breaking 200 (don't get me wrong, I know that's a great speed) But seeing as It's running on a sata3 card I was expecting 300+.
Under device manager it's showing "marvell 91xx config ata device" with no drivers installed - nothing on windows update and the drivers from the rocket site don't do anything.
Just out of curiosity I plugged the rocket into my spare PCI-E X16 slot and that seemed to fix it, I'm getting 350 odd read speeds (drivers still not working though)
Is this some chipset limitation that I am unaware of on the P55? If I leave my rocket plugged into my Second x16 slot I'm pretty sure that's going to bump my first one (where my 4890 is) down to x8?
To be honest I'm a bit confused
I guess the driver issue could be because I'm running W7 64-bit...
I've plugged the Drive into my motherboards onboard sata port for the moment untill I can figure this out.
Sorry it's such a long post, any help or idea's would be much appreciated
Thanks
mobo: MSI GD-80 P55
cpu: Core I5 760
Thanks
