- 20 Feb 2009
- Ashton-Under-Lyne
Your right to go wired, lower latency, and reduced packet loss.
I've gigabit'd up my entire house... Anything less would make me feel like I've cheating myself out of the absolute best !
Sweet, how much did it cost though and did you do anything in terms of being able to change the plugs/cables if the next standard wants higher bandwidth?
I'm pretty sure Cat6 cables (what you need for gigabit) do actually support faster speeds, it's just the end points that aren't fast enough (the switches, routers, NICs etc), and depending on how many ports you need, each switch will probably cost upwards of about £40 for the basic ones when faster than gigabit becomes a consumer network connection.
Cat5e only works on quite short distances for gigabit, so cat6 is needed for couse wiring etc (a patch cable would be fine as cat5e
Cat5e will suffice for even long runs. I should know, I have them in my house.
Cat5e is rated upto 90 meters or 295feet for gigabit and 100m alike.
Where ever you are getting your technical information from? May I suggest you change it..![]()
