HTPC = home theater PC; record tv, use for iplayer, play blu rays quicker than a stand alone player, music player etc
reduces the number of boxes under the tv for the price of a remote and a tv card
you should get a 930 to run as quick as the 950, saving a few £
I would go ati card the red matches the case !!!!
@Joe
as some 1 rightly stated
the SSD is a luxury rather than a necessity
you could swap for a normal HDD and that would save you
around £90 now and you can easily add 1 down the line.
the h50 ive heard is a decent watercooler for cpu, but unless
ur going to overclock you could easily get a good air cooler
that would do the business well. that could save you another £25
the i7 950 is basically entry level now if your going for an i17 build
because its so close to the 930 in price. if you want to save another
£21 you could drop to the 930 and not see the difference in games.
so you could shave another £131 off your lateast spec post
with minimal if not no performance loss.
In addition:
to get another £68 off you could drop to an EVGA 460.
but this is then starting to eat into performance and bring
th necessity for an upgrade closer, which "you" said you dont want.
now that your asking about a build around £800 throws
everything ive said and speced up in the air basically.
go i5 and 460 like the guys said to get around the £800 mark
but upgrading will be much sooner than an i7 and potential 470sli
goodluck
im not 100% but the i7 cpu's might come with a standard cpu fan with them
which im sure you could use until u have extra funds available.
if some1 could confirm this for joe would be great.
All Retail boxed processors come with a standard CPU cooler.
Only OEM processors come without. Now you can state your 100% sure![]()
yeah why not get the 5970 ares edition since its red and matches the red in the case.![]()
thanks willy
@Joe
yes m8 that a good 1. you basically paying an extra £10 for a lifetime warranty
compared to the others. which i think is spot on for a safety net.
sli 470s could be used for more than 3years i think and other brand warrantys will be expired.
i bought my 8800gts wen it was the dogs ball licks way back.. its only
struggled in the last year really. its going on 6 years now. so i think sli 470s
could easily get close to this. thats my view of working it out
I would remove the Blu ray player...Do you own/play any blu ray movies???
I would get a cheap DVD RW for now, and get a blu ray ROM later if needed. If it main use is for gaming Blu Ray player is another luxury xD
