That won't be a problem with the Gigabyte . . .If I can get 3.6GHz or 3.8GHz out of it then I think I will be happy
Take a look at asus![]()
I had looked at Asus M4A89GTD PRO/USB3 but having read up on it, it uses a switcher card for the PCIEx16 slots, so I'd have to have my 4870x2 in the 2nd slot, which would mean no room for sound card, plus it would completely block off the SATA ports.
what would be the best bet if I wanted to include Crossfire support?
That's a nice board lmfy2k!
I have it's little brother . . . similar to yours (£57) but uATX and AM2+/DDR2 running an AM3 AMD® Athlon™ II X4 . . . AMD® 785G chipset is great!
I like the heatsink and 8+2 PWM system on yours (mine is 4+1) . . . you should get some nice overclocks on that!
ASUS M4A785D-M PRO (AM2+/DDR2)
Good board if you have a stash of DDR2 memory . . . .
I just checked the ASUS website and it seems your right?My [M4A79XTD EVO] board doesnt have LLC
Well if its disabled and not doing anything you would think it wouldn't generate any heat!you would think it doesnt generate heat if disabled
the IGP is part of the NB which is always working so I'm not sure how anyone could tell? . . . PWMs are near also . . .one review I looked at seemed to infer it was the cause of heat near the cpu socket ??
Looks like a great board, it's price seems to be creeping up though? . . . £105.99 (4+1) vs £99.99 (8+2) on the ASRock . . .Either way I'm thinking that the giga 890GPA may be the best option anyhow![]()
Well the cheapest SATA 6Gb/s & USB 3.0 board on OcUK is £82.99 (4+1) . . . not a lot in it really compared to the 890GX boards . . .Xfire isnt an issue tbh.
