I have my iPhone (which I prefer), but the BBM is cool for keeping in touch with mates.
Because it's soooo difficult to use threaded text messages.
BBM is over-rated.
BBM is over-rated.
Spawn whats the release date on the 9780?
Someone mentioned the battery life - how long do you normally get between charges?
I love my Blackberry, had one since January.
Extremely good if you want to email a lot, have a portable calendar, use BBM with your mates. Main thing is email, as it always has been.
They're not so great for web browsing, I'd go down the iPhone route for that. I'm not a fan of touchscreens for lots of typing though which is why I picked the BB for email.
Battery life is fine, you just need to be aware that if WiFi is set to On, it is always On, so it will drain your battery quickly. I get several days out of mine without WiFi on, so it's more than acceptable. I've got an 8900 by the way, I like its compactness.
Think I might just get the Curve 3G, looks like it will run OS6 so should be fine.
Good device....curve series are one of RIMS best sellers and now with 3G its even better and yep it should run OS6...still waiting for the 9700 to get its first leak of OS6 myself.
Is OS6 coming to the 9700 officially?
Yes
http://www.youtube.com/watch?v=7-fKUzx10Eg
It's definitely an improvement, but still nowhere near Android.
