Is Intel still the SDD drive of choice?
7 Jul 2008
Newcastle upon Tyne
I bought an Intel 80g X25 (SSDSA2MH080G 1GN) last year and have, so far, been impressed.
I am now after a SSD for my laptop. The laptop is m ainly used as an internet machine so do not need a huge amount of space. Its running Windows 7 Pro in an Insperon
I was thinking about this:
http://www.overclockers.co.uk/showproduct.php?prodid=HD-006-IN&groupid=701&catid=14&subcat=910
Has there been much changed since the one a I bought a year ago?
Should I concider anything else?
Yes Intel support trim. They are still good performing drive, but some of the newer models from other manufacterers have overshadowed the intel SSD's a little.
No doubt Intel will be working on their next generation SSD.
Im still 100% satisfied with my Intel 80g X25.
So is there an upgrade for my exisiting drive to support trim?
u'll need to update the firmware of the drive.
intels are still good drives, but there new ones are faster and should be out by the end of the year. They are also double capacity
The other drives may be faster than the Intel drives in certain areas but I'd still recommend the Intel SSDs based on reliability, you hardly ever read of an Intel SSD failing, I've lost count on the amount of OCZ SSDs I've read about failing.
this guy speaks the truth.
the main reasons for buying the ssd are not only speed but the added reliability of having no moving parts, shock tolerance etc. but as its been with companies like ocz and even corsair they have firmware issues, drives bricking themselves etc etc.
if i were to get an ssd today it would be intel, otherwise id just stick to mechanical drives.
yep, that's the firmware you should have. They haven't updated that in a while and you should already be on that.
Make sure you get the new intel SSD toolbox software also.
My drive still does not support Trim as its a 50ns (G1) one :(
