BMW use it in the Cooper D as well!
To be fair it is probably a fixed problem now and the engines are wholly reliable. It is probably the most popular diesel engine on the road so can't be that bad.
You should definately look at the D5 though, may find within your budget and won't be quite as dull as the 2.0D, especially coming from a 182.
