Which one was it in Arnold? The one near the Vale pub and junction to thackarys lane?
I do remember seeing a pub called the Vale and one called the Ram??
I was driving in a manner appropriate to the conditions
I was stopped at a red light at the front, two lanes of traffic and a central reservation (with a fence running along the middle of the road). An Ambulance came up behind me with its lights and sirens blazing and I had to move forward infront of the red light ( but no so much as to block the junction). There was no camera but if i had of get points/fined for that i would SERIOUSLY contested it.
So you all think i should have just waited![]()
Take a pic of the lines. If they are sufficiently worn enough, you may have grounds for appeal.
I hope you're joking!
It wouldn't be unlucky for the ambulance, but it would be for the person who could be dying waiting for it to arrive.
Personally I'd be able to live with some points and a fine, whereas I wouldn't knowing I helped delay an ambulance and possibly lead to a death in an attempt to save myself £60.
highly doubt youd get an NIP if you were letting emergency services out? probably explains why you get tards sat there at the lights with a blues and twos going behind them because theyre scared theyll get sent to prison for crossing the white line
... i normally see blues and twos as an excuse to sod the traffic and get out their way. ive definately gone through red lights before to clear space to let them out, even once it wasnt viable for a copper to pass me but the road ahead of me was clear, so i just pinned it, actually left him behind and then pulled in at a bus stop ahead to let him by
if a driver would be penalised then that makes me loose all sorts of faith in humanity!!
Were you coming into notts from Mansfield way then? The ram is the opposite end of Arnold to the vale. If you need any pics of it shout up, the vale is only about 1km away, I can walk down there (google image might help to pin point where you were).
[TW]Fox;17406068 said:the emergency vehicle is not a defence.
