- 19 Aug 2010
Howdy,
I hope you're all well (because I need your help lol
So I got "Windows 7 64bit HDD imminent failure warning" last night and it naturally scared the hell out of me so would like some advice.
here's whats happened from the top:
- Firstly, my drive is a samsung HD203WI ATA 2TB.
- I recently replaced the PSU in my PC because it shorted out and broke completely. I have no idea what caused this and am trying to fix this as a seperate problem (i currently have my entire PC running on top of a cardboard box with 1 mem stick and a cheapo (but proven to work gfx card).
I believe that whatever caused this may have also screwed the drive at the same time but cannot be sure - looking at the components there was no physical damage or burn marks to give any clues.
- After replacing the PSU, The first time I turned it on, everything was fine - it ran and all seemed well.
- The second time onwards the power LED on the case stopped coming on when turning the PC on - apart from that, it all still worked and seemed happy.
- Forth or fifth time, windows stopped loading - it would stall on the "Starting windows" screen. Resetting and loading in safe mode would get me into windows, then restarting again in non-safe mode would load successfully.
I then got the HDD failure warning screen.
- I ran "chkdsk /r" last night and it appeared to complete successfully. windows would load successfully this morning but the power LED on the case is still out despite being connected to the mobo.
- I ran HDTune (lite) and performed a quickscan and got 100% green with drive health "Ok". Temperature of the drive never gets above 36 degrees.
- I *think* the drive is making a more aggressive noise now but I can't be sure - it may be just me listening for it because of what's happened.
- Unfortunately Samsung don't offer their diagnostic tools for windows 7 64bit - I'm emailing them later to see if they can do anything about it.
And that's about it - I'm going to run a full HDTune scan tonight (I've worked out it'll take about 7 hours to scan a 2TB drive to completion) and I'll post the results tomorrow but if anyone has any advice or suggestions I'd be very grateful.
Thanks,
Allan
Thanks,
Allan
