An overclocked 460 is slightly slower on average when compared to a 5850 at stock.
Overclock the 5850, and it is on average 10-20% quicker.
Ahhh great, I always thought a 460 1GB was better than a 5850. Cheers for putting that right now i know!
In response to this post.
Sorry, I could be wrong. But i thought the GTX460 1GB was a better and faster card than a 5850?
You sir, are definitely wrong.The GTX470 is barely faster than a 5850, hence its very close price point.
It was generalised because the majority of benchmarks vary with one another, and you're never guaranteed how well a card will overclock.
The link you posted uses a lot of TWIMTBP games in their review, so I'd say it's slightly biased imho.
As you said though, the 470 is the best value for money card atm.
Fair comments.
Also agree with the OC on any card not being guaranteed. I have another friend with a Gigabyte 460 GTX and although the temps are fine. Even with a voltage bump it wont go over 800 MHz. Very little in life is guaranteed.
This shows the 1GB 460 Sonic@800mhz being slightly behind a 5850@stock :
http://www.guru3d.com/article/geforce-gtx-460-review/16
This is in BC2 at 1920x1200 / 8xaa / 16xaf, which the op wants to play. The 470 is just faster at this res, but it's currently £30 more than a 5850 atm, going by OcUK's pricing.
If his budget is £200, then the XFX 5850 is the best choice. Even though it isn't a reference design, it will overclock slightly.
If he can stretch to £230, the GTX 470 is the better buy.
Because no one plays at 32xaa, nothing over 8, nevermind 4 is visually different really in bc2
why they only use 8xaa 460 can easily do 32x in bc2 at that res
all in your head![]()
