Which cat litter do you use?
We've got two queens who are feeding kittens, they pee like it's a national sport. The chick crumbs tend to turn to a solid lump once they are wet. Adding the worlds best makes it easier for the lumps to separate from the rest of the litter in the tray.
Interesting. Having used both in the last 3 months i've not noticed any difference in the way they handle pee or poop. We only have 3 kittens of course so no queens.
...We only have 3 kittens of course so no queens.
Try pouring half a cup of coffee into the litter tray, see how well the chick crumbs handle it ;)
And obviously, if i don't add something to the crumbs the kittens try to eat them .....
I use some "litter crystals" looks like how it sounds. A bit pricey but u don't need much and it dose a good job of keeping the smells away as well
Bob Martin - Premium Litter crystal it says on the bag , sold at the normal places
Cheap cat litter from pets at home - 30L bag of the stuff under a tenner iirc. Not those damn woodchip ones... they really hurt your feet when you step on them.
Yours will try and eat crumbs but not worlds best? Ours only tried to eat the Tesco Value stuff we started with, everything after that has been ignored foodwise.
Catsan for me, all the others I've tried the moggy has been thoroughly unimpressed with, especially the woodchip stuff which seems to be useless.
Catsan Clumping and then scoop it once every day. (Tried a bunch including wilco and normal catsan but both would smell bad after a few days)
With two cats, it never smells. We add more as it goes down and then empty it completely once a month or two.
