- 8 Aug 2010
- Oxfordshire
Ejizz;
As I have pointed out, performance per mm^2 is only related to the cost of the die, and this is a small part of the retail sales price.
Performance per watt is strongly related to the specifics of the architecture, and how it operates on a particular process. It is a tricky beast.
Yes it is, software processing is less efficient than dedicated hardware processing, it's just a fact that you can't get away from no matter what you do to change your architecture.
As for the rest - I have made the point many times now that Fermi is the first generation of a new design paradigm, whereas Cypress is towards the end of an older design process (read my previous posts for more detail).
Fermi is in a different situation, GPGPU architectures like Fermi rely on software based multi-function processing, and software solutions are inherently less efficient than fixed function hardware solutions.
GPGPU architectures have an inherent efficiency disadvantage you can't get away from.
Hence why I said Nv needs two fundamentally different GPU architectures if it wants to continue down the GPGPU route and still be competitive, because as current chips are now hitting hard TDP walls, the winning architecture will be the most efficient architecture.
