That depends, are you standing on the roof offering your PC to the gods?
If not, I wouldn't worry.
It's OK with just thunder. As long as there's no lightning you'll be fine.
 Both my brother and sister actually thought that you could get lightning without the thunder and vice versa. I had to explain to them that the thunder is the sound of the lightening, but light travels faster than sound so you see the flash then hear the thunder.
.just wanted to know. Shold i be using my pc whilst it is thunder and lightening? i have surge protection on my extension cable and mother board has surge protection.
Should i be worried?
Because usually when we see one, we hear the other (i.e. the sound it makes).
With thunder or lightening that isn't always the case. Lightening can occur very high up so that it's essentially invisible to the observer on the ground, but he may still hear it. Or he may see it from miles away, but the sound's dissipated by the time it reaches the observer.
Lightening = weight reduction.
Lighting = you know what that is.
Sort it out folks, the UK schooling system isn't that bad.
Skellingtons and chimbleys.
With a name like blitzyuk, I wouldn't even touch a PC.
Where in Tamworth do you live?
Why do we as people feel the need to give the noise that lightning makes a seperate name?
If we see a car passing we don't say "oh look, there's a car & broom broom". Or if we see fire we don't say "oh look, there's some fire & crackling". Why the need for "Thunder & Lightning", when, to be fair, it's just lightning.
Sorry, just wondering aloud![]()
