Gaming Desktop.
25 Sep 2010
Basically, im wanting to purchase a gaming desktop. I have about 600-1000 pounds to spend. Mainly to play Cod4 and Black ops and other games. Also to do coursework and maybe record. Just wondering what specs i would need to play Cod4 at full fps.
Cheers.
Done the spec below, what size monitor are you using.
Your basketProduct Name Qty Price Line Total
Intel Core i7 950 3.06GHz (Bloomfield) (Socket LGA1366) - Retail £217.36
(£184.99) £217.36
(£184.99)
Asus GeForce GTX 460 1024MB DirectCU GDDR5 PCI-Express Graphics Card £172.71
(£146.99) £172.71
(£146.99)
Gigabyte GA-X58A-UD3R Intel X58 (Socket 1366) DDR3 Motherboard £144.98
(£123.39) £144.98
(£123.39)
Kingston HyperX 6GB (3x2GB) DDR3 12800C9 1600MHz Triple Channel (KHX1600C9D3K3/6GX) £111.61
(£94.99) £111.61
(£94.99)
Microsoft Windows 7 Home Premium - Retail (Full Version)(GFC-00025) £105.74
(£89.99) £105.74
(£89.99)
Corsair TX 650W ATX SLi Compliant Power Supply (CMPSU-650TXUK) £79.99
(£68.08) £79.99
(£68.08)
Coolermaster CM-690 II Lite Dominator Case - Black £58.99
(£50.20) £58.99
(£50.20)
Samsung SpinPoint F3 1TB SATA-II 32MB Cache - OEM (HD103SJ) £44.99
(£38.29) £44.99
(£38.29)
Titan Fenrir Evo CPU Cooler (Socket LGA775/LGA1156/LGA1366/AMD K8/AM2/AM2+/AM3) £35.99
(£30.63) £35.99
(£30.63)
Sony Optiarc AD-5260S 24x DVD±RW SATA ReWriter (Black) - OEM £15.99
(£13.61) £15.99
(£13.61)
Sub Total : £841.16
Shipping cost assumes delivery to UK Mainland with:
DPD Next Day Parcel
(This can be changed during checkout) Shipping : £11.25
VAT is being charged at 17.50% VAT : £149.17
Total : £1,001.58
I have not, are they any good, As I think the last lot form XFX did not get a warm welcome :confused:
Personally I'd change the i7 for an i5 and get some extra gaming beef from a bit better GPU. (like a 470).
Just me though. :cool:
Im not much of a wizz with computers. So i might need a bit of help. Can you get custom built desktops from this site or are they only bundles/build your own?
By the time you add an operating system and upgrade the graphics card it will cost well over £1,000.
Cheaper to get RJC's build and overclock it yourself.
Not difficult so to speak, just time consuming (depending on what you aim for). Just have to read up on it and not rush things.
Games are more heavily reliant on graphics card and anything above the amd phenom II x4 955/i5 760 is not really necessary for gaming and either of these processors should last you a long time to come. Given what else you plan to use your system for I think if you're looking to spend towards the top-end of your budget, then more invested into the graphics card (and therefore better gaming performance/longer lasting) and the addition of a solid state drive would be more beneficial to you than spending a considerable amount more on the i7 950 cpu/mobo and getting a less powerful graphics card (and so lesser gaming performance).
So here you have the amd path covered (should you prefer to go intel then you'd simply swap the cpu for the i5 760, the mobo for an socket 1156 intel mobo).
-The more powerful gtx 470 is included here, which gives a very decent performance boost over the 1gb 460 (and you get mafia 2 thrown in).
-A cracking solid state drive (sata6gb/s). They are really popular at the moment. You have your 1tb hd included in this build for most of your games, music and other programs, but on the solid state drive you install windows, whichever internet browser you use, one or two of the games you play most regularly (or those which put the most strain on your system in terms of load times) and these programs will load incredibly quickly.
-A great motherboard which supports sata6gb/s (which is the fastest speed available for your ssd), usb3 and crossfire should you decide to use two ati hd**** cards in future.
-4gb memory is plenty for gaming and these patriots have low cas7 latency.
-CM90II adv is a corking case! Great looking, excellent cooling with its 3 (very quiet) fans, tool-less.
-Excellent cooler in the titan fenrir evo which will keep your cpu running nice and chilly and will allow you to overclock either cpu should you want to.
If you're looking to spend the maximum of your budget then frankly, I believe for gaming this would be the better option over the £1000 i7 950 specced earlier. You're getting a more powerful graphics card (which should last longer also) and a brilliant solid state drive which will improve load times (windows, whichever games you put on there) considerably.
(£184.99) £217.36
(£184.99)
(£146.99) £172.71
(£146.99)
(£123.39) £144.98
(£123.39)
(£94.99) £111.61
(£94.99)
(£89.99) £105.74
(£89.99)
(£68.08) £79.99
(£68.08)
(£50.20) £58.99
(£50.20)
(£38.29) £44.99
(£38.29)
(£30.63) £35.99
(£30.63)
(£13.61) £15.99
(£13.61)
Sub Total : £841.16
DPD Next Day Parcel
Total : £1,001.58
I have recently changed my price limit to 600-700. Could you please do my specs again? If thats alright...
