Wallet like this or UK distributer
You should never put your wallet in your back pocket, you're just asking for it to be stolen!
Done it for the last 7 years, never had a problem. If you're in a tricky, crowded situation you're always subconsciously aware of what's going on around you and if you look mean enough people won't come near you.
Wallets don't fit snugly in front pockets. It bulges in smart trousers and looks wrong. In jeans, the opening is too tight so you have to stretch and push them down in an attempt to get the bloody thing in.
Wallet = Back pocket.
Then your jeans are too tight?
My wallet is quite small, though.
16 cards is a bit much but perhaps understandable. i need 9 on me trough the week plus place for business cards. keys though is one i don't get. people carry far too many keys when only 2 is really needed, yet i see people with every key to every door plus stupid fancy key chains.
front left for wallet and key oas other have said and front right for phone. how anyone could every think to put their keys with their mobile i don't know. back pocket for random bits of things i need to hold. back pocket is such a stupid place for your wallet, i can't see 1 single reason to use it for your wallet, not one single reason other then to fit in with other men.
one thing that really annoys me is finding a wallet that has a good space for cards, is thin, and a decent small area for a small amount of change.
Side Pocket or front left depending if its jeans or cargo type things. If its too bulky in your front pocket then either your trousers are too tight, wallet is too big or have to much crap in your wallet.
Top one is a variation of my wallet, not too bulky? And my jeans certainly aren't too tight....Just normal denims.
Surely a really thin wallet with 16 cards is just going to make it really thick and possibly not even close due to being designed to be thin!
I'd just ditch the cards you don't need or don't use often. Yes it might mean you miss out on those Nectar points next time you go shopping, but you could always just remember to take it with you when you know you are going shopping.
You don't even need to take loyalty cards like tesco or nectar. Keep the reciept and claim the points next time you have the card on you.
[FnG]magnolia;17457280 said:
Do you wear a suit?
Nope, talking about jeans. Although my wallet is pretty thin (usually less than 3 cards) as well as the iPhone, so that's probably why I never notice them. I wouldn't trust leaving my wallet in my back pockets though, they feel far too loose and easy to pickpocket.
Phone in left pocket and wallet & keys in right. Loose change in right back pocket and a couple of tissues in left back pocket. Always.
You live in Clydebank and have 16+ different cards. ROFLCOPTER.
You get that lot stolen in one hit (which is highly likely living in that ****hole) and you're going to be royally screwed.
How about leaving your inch thick wallet at home and going out with what you actually might need in a more slender normal wallet...
as an ex drumchapel man i could not agree more lol
[FnG]magnolia;17456986 said:
Indeed :D
From a practical point of view, putting a wallet in the front pocket of suit trousers would just look wrong. ?
pft if you're wearing a suit it goes in your inside jacket pocket.
