How do I ensure my directx drivers are up to date?
18 Mar 2010
Just bought civ 5, and it will only run in directx 9 mode.
Looking on tinternet for a solution, I was advise to make sure my directx drivers are up to date.
How do I do this?
Have you tried running the dxsetup thats in the civ5 folder ?
Yes thanks.
The problem I am finding is that when I click to launch the directx 10/11 version, it goes to a black screen and then...... Nothing happens. I.e no intro movie. I disabled the intro movie, and still nothing happens.
The directx 9 version works fine thus far.
Yes thanks.
Ah my bad, thought it was that you didn't have the dx10/11 option. Afraid I have no ideas then.
As has already been said, you should be on some version of DX11 with Windows 7, but if you type 'dxdiag' in to the run box and press enter, you should get the version number if you want to check.
Thanks guys, I will try asking on the 2k forums. Irritatingly, I haven't noticed anyone posting exactly the same problem as me.
A different question I have - I bought the retail version of the game and registered it via steam. It doesn't show up in my steam games library - I.e I have to launch it using the desktop shortcut. Is this normal?
Ok I just tried running metro 2033. It started up fine, I checked the video preferences and it was running in directx 9 mode.
I changed it to directx10 (directx 11 was greyed out).
I exited the game and reloaded it - now the same thing happens as for CIV V, I launched from steam, and it went to a black screen and got stuck there.
Therefore it would seem that I am having a general problem running applications using directx10/11.
I suspect this may have been cause by updating my ati drivers a few days ago.
Anyone got any idea what is going on here and how i could fix it?
