Basically, as per title, I fancied trying a couple of floorstanders to replace 2 of the sattelites and ordered these, if I can't use them it's not a biggy as I also have an amp downstairs with 2 old broken Jamo speakers ( foam rotten due to age) but I was wondering if someone could tell me if these speakers can be used on my Z5500 without damaging it :
2-way bass-reflex
Size 910 x 180 x 238mm
Weight 8 Kg
Woofer 140mm
Tweeter 25mm
Impedance (Ohm) 6
Frequency Range (Hz) 48 - 20.000
Power (W, long/short term) 100 / 140
2-way bass-reflex
Weight 8 Kg
Woofer 140mm
Tweeter 25mm
Impedance (Ohm) 6
