Yep. You can't get out of the pits until there is no one coming down the pitlane behind you - regardless of how far away they are.
Normally means a pitstop which should be 3 seconds takes about 10-15. Yesterday I came in 3rd, went out 22nd![]()
Codemasters say either ignore the pit call, change the compound or change strategy to pit earlier/later.
Does that work?
