Sub £100 Dual Head Graphics Card For Running 2 Screens
11 Sep 2005
Hi all im after a Dual head graphics card sub £100 that can give me 2 screen outputs. The connections they will be running are VGA but DVI adapter to VGA can be used.
Any suggestions would be great.
Thanks :rolleyes:
I've installed dozens of Radion HD4350s for clients, they're cheap as chips. 1 DVI and one VGA. Afaik they're only available in PCIe
Edit: I'm assuming gaming isn't a priority! The ones I've used are Gigabyte models, can be had for sub £30
I have a 9400 at work, it has 1GB ram which helps with lots of Windows open and cost £40. Does light gaming without needing extra power too.
Hi there, may I ask what you will be doing with the machines? Anything graphics intensive or can make use of GPGPU power?
If not and you just need a cheap display card, then the suggestions above are great. I would personally suggest this HD 5450: it costs £38, can output to up to three screens (so long as one is via the displayport adapter), uses passive cooling so it's silent and is uses hardly any power.
+1
Depending on what you're doing, you can get a cheaper card. I would wait for next month's 6000 series... ;)
If you don't care about performance, the gainward 9500GTs come with 2 DVIs and an HDMI socket. Their also passively cooled and use very little power :)
I really don't think it does.
I think it does, I got sick of the 256MB card that came with the Dell originally because it was *constantly* stuck in repainting windows. You could see it going scanline by scanline. Maybe you only notice it at 3300x1050 resolution.
Edit: 1GB is way overkill, but that's what they had in the little computer store near my office when I got frustrated with the crap card supplied and put a new one on expenses :) FWIW the old card was an ATI x1300 or something.
