Modding your Fan Controller
rjk
rjk
OcUK Staff
8 Aug 2007
[apologies in advance for crappy pics]
The past few weeks I have spent hours trawling the internet to find a fan controller.
whilst the prospect of spending £100+ on a smart controller such as the fantastic Aquaero or Tbalancer was quite appealing, the fact that neither of them look particularly great or match anything in my current build is a bit offputting.
whilst the lure of a usb interface and smart cooling options would suit my new '6 fans only' setup, it is not ideal from an aesthetics point of view.
i went back to the idea of an analoge fan controller as it was the simplest idea.
i used to have the old plain ZALMAN ZM MFC1 Plus controller and it worked well but i noticed Ace Modder managed to get some of the Lamptron models in at work
Lamptron Fan Controllers
these are regarded as a great brand specific to fan controllers so i thought i would try one.
everyone who knows me or has read one of my build logs knows that i hate flash lights and that subtle is the key.
i went for the Lamptron FC2 - this is the cheapest in our range but only by a few pounds. the reason it is close to the next model up [the FC5] is because the FC2 sacrifices led screens and all that rubbish for raw power
the FC2 is a rheobus controller that is capable of 45w per channel
this means you can run Delta fans on it. not that i will, but the capability is there. the controller is well made and whilst it is supposed to cause some fans to hum when they are at really low speeds [from what i have read in reviews], i have only used decent fans with it so far and had no issues whatsoever.
the cool addition to this controller is that every channel can be switched off which my previous controller [ZALMAN ZM MFC1 Plus] was incapable of.
this means that i can switch off my 240 radiators fans and run my system off a 480 radiator on low speed if i want. the flexability is there which is what i wanted.
however. whilst the controller itself is a very well made piece of kit, the reason i went for this controller was for its features. i wanted to make the controller fit into my build and heres how i did it...
first i took the controller apart, this was fairly easy as i had to remove 4 screws and pull the knobs off the controller.
after removing the face plate from the controller, i prepared the bezel that i would be using for the mod. in this case, a vented bezel from lian li. the entire front of my TJ07 will soon be filled with these bezels so it will make the controller blend in really well.
i used the dremel to cut off the tabs on the side to be left with a front plate that resembled the stock one that lamptron fitted. i used the lamptron plate to create small drill holes in the bezel for each knob on the controller. i then used a larger drill bit to widen the holes. i wanted to keep the original face plate in good condition as this mod is totally reversable which means you can customise the controller then put it back to stock if you ever sell the controller on.
the lamptron controller has a row of LEDs that light up the area around each knob on the controller. LEDs are not required for me as subtle is the key, if you do this with a blank face plate then they will be covered anyway.
i found some foam that comes in the bezels of the antec 902 at work which i thought would do the trick. but i guess you could cut your own. the foam helped to bulk out the bezel to the same depth as the solid stock face plate on the controller so it is fairly required. [i can get these foam strips easily so message my trust if you need one] i poked holed through with scissors to match the bezel.
the bezels i am using have a mesh dust filter behind them so i put this inbetween the foam so that you couldnt see it through the little holes. it makes it look a little more stealth and it blends in with the other bezels that way.
after putting all three layers together then it is ready to go straight on to the controller and have the dials replaced. the pressure of the controller dials keeps the new face plate in shape.
I think it is a case of 'Mission Accomplished'
this mod took me 15 minutes, cost £25 and is fully reversable. give it a go, if you are looking for a new fan controller but are looking for something to match your case, this may be it.
[before you mention that i scratched the top left corner of the bezel, i know i did, i dropped it because i am clumsy. a new bezel has been made and it has been replaced already :D]
Nice mod! Was trying to do the same as i bought the silver 1. It looks naf in a black case. I think i went wrong in trying to do this with the plastic drive bay covers. The grill you used is it the li lan metal ones?
thats right, they are lian li. i am using them all down the 7 bays on my TJ07 as i am mounting a 240 radiator in there so i need some air flow.
simple but extremely effective, nice work as always from you rjkoneill. not that i am a fan boy but your build inspired me to do something on my MM ufo case.
the simple ones are always the best. i love reversable mods, its good to know you can put something back to stock should you ever want to sell it on. the LC2 is a really good controller and made this mod a piece of cake.
as i said in th OP, it took 15 minutes, which is nothing really. especially considering the time and research i have been doing looking at fan controllers recently [terribly sad i know]
good to know its inspired. would be interested in seeing your UFO Duesix, i do love MM cases. one day i may get one...
one day ;)
exactly, the same principle can be used for things like vandal switches and lighing controls etc.
Looks great mate :) My fan controller is a 3.5" one that doesn't quite fit my 3.5" bay :-/ so it's just sort of wedged in there... I might think about doing something similar with mine :) Good job!
i have a feeling some company will start building fan controllers that look like this,
VERY well done. it looks SO GOOD, a lot better than any other fan controller i have seen
Nice mod mate :)
I was thinking of doing he same thing with my Zalman to match up the fronts I have, but I'd need to buy another 4 silver bezels and I only need two :)
Are you going to stealth a CD-Rom drive in a similar way? I'm not sure how that would look, probably ok, I've got a flat Alu stealth on mine at the mo.
thanks guys,
@ mr Bif
i dont use optical drives so i dont need to stealth one. i assume that the same method could be used though with the foam being used to block the view of all the gubbins behind.
one day ;)
one day when i have enough posts it will go on sale through MM ;) save on import costs :D
Looks rather nice rjk, im using those vented bezels on my lian li a70f, though my stock zalman zm-fc1 plus and blu ray drive kind off spoil the look with their led's.
Nice mod mate. Personal preference would be to have the plain back plate rather than the mesh style (inc the top slot) to keep the smooth looks of the TJ flowing but it all matches so I see why you chose that style.
Oh, and get a MM case m8. While they don't compare to the features and build qulity of lianli or silverstone they make up for it in size and the possibilities because of that ;).
Cool mod there Rikoneill hope you dont mind but i think i may borrow this idea somewhat and apply it to my current Lian-Li A20 Mod
Ive added a couple of cathodes to the build and currently losing a pci-e slot which is taken up by the power switch for the invertor.
Not only that its a pain in the ****** moving the sytem forward evrytime i wish to turn them on and off.
which then frees up my last Pci-e slot so i can add in another single slot 8800gt for folding purpose's.
Great Mod,i`ve got some spare Lian Li bay covers,they`re not the perforated ones,but i reckon the standard plain blanks will do the job.And i thought i`d finished my Case.Damn you Rikoneill !! :p;)
