I'm running outside on a pebbly surface so I assume that will slow me down. Running in a t-shirt and jeans with trainers.
For the first half a mile I'd say I run it very fast indeed. I just seem to get knackered very quickly after that. My posture isn't the best in the world, though I am trying to rectify this now.
This is a joke, right?
1. Change the jeans to shorts. Unless its pelting it with rain or there is a significant wind chill then shorts are the way to go. You will find running in jeans to actually affect your pace as they are restrictive.
2. Slow down. Seriously. Running fast may feel like you are doing well but its no good if you have to stop before you reach the (relatively simple) 1-1.5 mile mark. How far do you go till you need to stop ?? I bet if you run at a pace that's albeit slower than your first section, your overall time will come down as you can run for longer... Plus, IMHO, running slower and longer builds cardio better as your body is in a sustained workout as opposed to quick bursts followed by rest (that type of interval training is useful for other areas)
IMHO, running is a mental sport as well as physical. Your may think your body is tired but just keeping your mind focused can help...
, but there are some good points made. I'll go for a run now and see what the difference is. I find it hard to pace myself (obviously i'm not going at an all out sprint, but slowing down seems to tire me out at the same rate).
p) as it really is cold at the moment and the last thing I want is a chill. I forced myself to run slower and take a small break during the run to stop myself being overwhelmed. This bought my time down to around 12 mins which was a marked improvement.Well that run went a fair bit better. Had to wear jeansp)
You don't need to be stacked for the army fitness tests.
You should easily get to the required press ups, sit ups. It's the running that is harder.
I can't believe you run in jeans.![]()
Have you calculated the run as in.. too long or too short? You got selection coming up or something?
Even so, some bulk would help haha.
I think I calculated the distance (I'm running round a block of houses) wrong and I think I've been running 1.8 odd miles
Pressups and situps are still no gain at all. Is there a particular muscle which is letting me down?
Well that run went a fair bit better. Had to wear jeansp) as it really is cold at the moment and the last thing I want is a chill?
