- 17 Sep 2008
If you don't get Win7 Professional or above (which has XP mode), you could install VMware Player, create an XP virtual machine and install your existing XP printer & scanner drivers into that.Hi,
Thanks for the repliesThe reason I want to go back to XP is that one or two programs don't work under Windows 7, example picture it. I use that program a lot to make cards and bussiness cards.
I have tried "compatibility" mode but it still does not work under that either.
Also my printer and scanner don't work under 7 either.
VirtualBox as mentioned above is another alternative, but I've always found its USB passthrough support to be flaky at best on a Windows host, particularly 64-bit. FWIW, it does seem to work flawlessly on a Linux host, which obviously isn't much use to you.
