Dungeon keeper 2 (or 1)
Caporegime
30 Jun 2007
Wales
iks there a way to play with on win 7 x64.
I remember trying dk1 ages ago but the gfx just flickered madly :(
I managed to get DK2 working on Vista by turning off Hardware acceleration.
Also if you search online there are also quite a few tips available to get it working. Unfortunately, it seems that there are lots of different issues so its basically a case of trying every idea suggested and hoping one of them works for you .............
hate you, Tefal... im totally going to buy a copy tonight ^^ (lost mine in my house move)
had the massive PC box and eeeverything! i miss those!
IT WORKS!
Had to apply this fix
Q: Game stops when loading a map. LOG file says:
Error: setup_screen_mode: Unable to setup screen resolution
640x400x8 (mode 10)
A: The problem is that your drivers can't support 640x400 mode.
Change the resolution config lines in KEEPERFX.CFG into:
FRONTEND_RES=640x480x8 640x480x8 640x480x8
INGAME_RES=640x480x8
but i also added 1920x1200x8 to the in game and it works (press alt +R) dungeon keeper in glorious 1920 :D
Also the FX guy has included loads of custom campaigns and what i think might be from an expansion there's a massive list to choose form including the originals.
This man is a god.
weirdly if icycle back round through the reses 1920 runs as
So cycle through to your desired ress then quit and restart to get the proper zoomed out view.
omg.. level one... YOU TEASE! :o
remember level 3 with the block of 3 infinite gems :p
loved that levl in the demo :D
can't get the stema voerly to work (long shot :p) and windowed mode is impossible but alt tabbing out and backi nseems to be fine, and the seond screen is playing films/tv on windows media player no problem at the same time.
