- 8 Sep 2003
- Was 150 yds from OCUK - now 0.5 mile; they moved
NZXT Phantom Cases in black and white are now in stock. With red to follow next month.
NZXT Phantom Enthusiast Full Tower Case - White @ £129.99 inc VAT
NZXT presents the cutting edge Phantom Full Tower Chassis. Designed with sleek, pristine contours, the Phantom radiates personality and quality. As with all NZXT products, we strive to set apart our customers from the rest with unique, original designs – we run the extra mile so you won’t have to settle with the typical rectangular box. The Phantom delivers high performance cooling advantages with 7 fan cooling options, dual radiator support, quad watercooling cutouts, and five 20W per channel fan controls. An innovative 5.25” screwless system, vast space to encompass 7 hard drives, and five 5.25” bays enable smooth customization. Establish your power, your presence.
- High Performance Cooling Advantages
– Phantom’s extensive cooling capabilities include 7 fan cooling options with dual 200mm, single 230/200mm, triple 120mm, and front 140mm fans.For enhanced control and expandability
- NZXT includes dual radiator support, quad watercooling cutouts, and an integrated fan controller with up to five 20W channels.
- Simple Installation
– Phantom celebrates an array of innovative features designed to enhance every stage of the build
- Meticulous cable management is easily attainable with large spacing behind the motherboard.
- Innovative all-new 5.25” screwless rails make installing and swapping HDDs an effortless process
- Rubber grommets dampens vibration during operation.
- LED on/off button to control fan lighting
- Rubber PSU and case feet to reduce vibration
- Easily removable front and top panels
- Top mounted USB, Audio/Mic, and E-SATA ports.
– Features support for larger heat sinks, graphics cards, and E-ATX motherboards enabling enthusiasts to include any of today’s hottest components
- Vast space within the enclosure allows for 7 hard drives with SDD support and up to five 5.25” bays
Only £129.99 inc VAT.
ORDER NOW
NZXT Phantom Enthusiast Full Tower Case - Black @ £129.99 inc VAT
ORDER NOW
ORDER NOW
ORDER NOW
, shall test when they are all in.
