Any men use hair straighteners?
I use straighteners, but only because my hair is truly diabolical without them. It probably wouldn't be so bad if I had short/er hair, but I suit a longer look much better than what I imagine myself looking like with a low-grade haircut.
the irony is in his name....
One could say the same about yours in an abstract way.
:D
On topic i was thinking of getting some ghd's when i can afford to, will have to make do with some chepo ones for now.
Decided to try something different than the normal shampoo / conditioners that i use, picked up some Aussie 3 minute miracle frizz remedy and i must say i love how it makes my hair feel.
The "GAY" comments don't bother me, i know a lot of them are in jest and even if they aren't it's no skin off my nose as i know who and what i am. :p
Sometimes but you really shouldn't be asking a forum filled with computer nerds/'macho' guys who think that soap is gay and haircuts over £15 is retarded.
The guys who do use hair straightners will not spend their time on a computer forum. Normally.
So, hypothetically, IF I spent maybe £35-45... Maybe more for highlights occasionally... on a haircut, and spend, maybe, £100 on hair straighteners, plausibly use hair products daily costing around £30.. I.. I mean They shouldn't/wouldn't be on this forum...
I would have job using any straighteners as i look like a boiled egg,or if i let it grow i end up looking like Terry Nukins...:cool:
Haircuts over £15 are retarded :confused:
