Tyre pressure?
RTFM TBH![]()
did you go over a pot hole or anything as this can trigger the sensor.
Yeh I did read that on another forum.. although my DSC light has not been on since so I hoped that problem had gone.[TW]Fox;17571155 said:Those two are likely related. DSC will shut down when battery voltage gets too low. It's almost certainly the alternator, though there is an outside chance its the belt.
Z4 03 3.0l 60K
