Watercooling, ready to go?
20 Nov 2009
Bangor NI
I'm lacking fluid (cant decide on colour :D), anything else I've missed?
I also might switch the copper block for nickel, any other suggestions?
De-ionised water and some Primochill liquid utopia would be good for coolant. It's what i use and does'nt make the tubing go cloudy either. If you want colour then buy coloured tubing. You will need more than 1 meter as well.
Staying with the colourless fluid idea, I've got some blue cathodes which should look well :)
I'll add an extra length of tubing, thanks.
that stuff is alright
probably the best choice.
i wouldnt imagine more than one bottle would be required.
One bottle will be enough in the op's case unless you are like me as I found my new watercooled loop ended up taking almost one and half litres :eek:
So I'll switch out for 3/8 tubing and the TFC compression fittings, which actually works out cheaper, good news because I'm pushing my current budget already ^^
Careful with the compression fittings, the masterkleer has quite a large outside diameter, the compression fittings might not fit.
Can anyone verify this?
The fittings say they're good for a 1/2 inch. The tubing says its outer diameter is 12.7mm which is half an inch...
Oh the confusion! :)
I dont like 7/16" masterkleer with those barbs, I use 3/8" for a tighter fit. Seemed too easy to pull the 7/16" off.
???? I had to use hot water to soak the end of the tube to fit them on the same ek barb fittings and had to hacksaw them off when I disasembled the loop later.
Its possible I might have been thinking of different barbs, and I didnt check the make of the compression fittings. I probably should have kept quiet :D.
Oh the joys of a free weekend!
There seems to be a fair few complaints about the revision 1 of the pump/res combo lurking around the internets!
I'll get the rev2 part off a different etailer and I think I'll have to do the same with the waterblock....I'm in love with the full nickel one ^^
No where (besides the bay) has the full nickel blocks!!
Oh well!
I've also changed the tubing to 1/2" black XSPC, I'll try find a blue anti kink coil to match my black and blue cable braiding :)
