) added another metre of tubing.
that stuff is alright
probably the best choice.
i wouldnt imagine more than one bottle would be required.
Careful with the compression fittings, the masterkleer has quite a large outside diameter, the compression fittings might not fit.
I dont like 7/16" masterkleer with those barbs, I use 3/8" for a tighter fit. Seemed too easy to pull the 7/16" off.
???? I had to use hot water to soak the end of the tube to fit them on the same compression fittings and had to hacksaw them off when I disasembled the loop later.
A few anti-kink springs (if u want good loooking ones) in case u have to do any tight turns would help
