So is a 5770 a rebranded 4890 because it has 800 shaders? Neither will a 6xxx with 800 (or in the ballpark) be a rebrand, douchebag editor talking utter rubbish, his list of names quite literally makes no sense, neither of option 1 or 2 in his little table, is accurate, they would only be possible if there were ONLY two new cores, and AMD have already confirmed that they are doing a top to bottom refresh, or thats what we've been told, AMD hasn't officially said another word, at all, and making the odd slide isn't difficult and frankly I don't believe much of anything so far.
The "specs" I've assumed for the 6series are ones I guessed at months ago before any "leaked specs" were even being rumoured.
The names are, as always irrelevant, if AMD brings out a new circa 1900 shader core, 1200, 800, 400 and 80, new architecture or old, thats a new series of cards.
Theres not a whole lot of difference between the 4870/5870 cards, just doubling the numbers, both series have 800, 400/80 shader cards, are any of them rebrands, no, infact frankly its likely the entire new 6xxx series cards will be a MUCH bigger architectural change than 4 to 5 series.
Rebranded, get this right, would be if AMD kept the entire 5970 through 5450 set, used the SAME cores and called them 6970 through 6450, thats not whats happening here.
Infact, even if they did reuse the juniper core, if it provides the same performance as an equivilent "new" core anyway, and they likely drop the price point for the same performance, then there still wouldn't be an issue.
If they do rebrand anything in a crappy way I'll happily call them on it, but based off a few rumours with no shred of evidence. All this "fact" coming from a picture of an AMD card with 6870 on it.........
