finally, after months of planning and setbacks I have finally manged to get the new hardware and parts fitted to my system.
10am this morning and I finished at 7pm.
really pleased with the outcome this time and I think that I will be drawing the line under this project now.
I will let the pics do most of the talking but will cherp in with explinations if need be.
also please check the video at the end, its not great quality as it was a last minute idea and was shot with an iPhone. but it should give you all an understanding of just how quiet the system is now.
Seriously, I cant even tell its on!
Ripped everything apart and started again...
Riveted the custom rear panel in place
looking sleek
hello old friend...
midplate cut, filed, de-burred and bulkhead in place
straight down into the D5
and into the Quad, Tygon Goodness
the tubing route i had planned in my head for months worked brilliantly
facepalm
PA 240 mounted in the drive bays
things are going to be tight. i moved it back so that it had a bit of space to suck air and wasnt right next to the mesh
had to get creative with fittings to make this work
Gigabyte with their 'not so' stealth backplate
ssds on velcro
very tight squeeze
Xigmatek blueline XLF fans looking pretty sweet
starting work on the board...
The Dominator GT will have new heatsinks soon, i plan on getting some of the extended fins but more of that later
got some matching screws for my CPU Block
wanted this to be the primary focus of the build
Start of the tubing routes
tubing finished
really pleased with how this turned out. really neat.
fitted the last fan and ran out of black screws
. will pick some up at work on Monday. also had to use three of the fan extention cables from the fan controller. of course they werent braided so an emergency braiding job was required and completed on all three cables in 20 minutes.
speed braiding is my new speciality
the coolant I used is very good. Mayhem Pre-Mix X1 UV Blue, supplied by the brilliant Mayhems Dye. it looks incredible in the system, the pictures really dont do it any justice at all.
Hello Pretty
fitting the front bezels
totally transforms the look of the case, i prefer this to the stock bezels.
shoddy SSD mounting at the moment. i plan on sorting this out soon
then i installed the final component.
after all the faffing with MurderMod I gave up any hope of ever seeing a luminous panel.
instead i chose a lian li LED strip. took 5 seconds to fit. good times.
Lights off...
makes the tinted windows look incredible
heres the system at half fan speed folding away happily at 100% load on the cpu and gpu
thats it for now.
thanks for checking it out
rjk
