- 22 Sep 2008
- Burscough
Drivers?What you trying to say!?!
Hm...Not sure what to do then...unless i get my friend to run a fault code diagnostic on it see if throws anything back? Problem is by the time i've got there the fault will be gone!
I'll check the wiring tomorrow, see if theres anything else worn through...Other than that I did think about the spark plugs, but the coils ill have to have a think about, the way people describe it, it does makes sense
Thank you all
The thing that doesn't quite match up with the coil packs is that you say your problem goes away after a few mins? That tells me that you may have to look elsewhere for the underlying problem.
off the 'bay, and I bet they have never been changed
