lets not make it a 10 page spec please. again
IIRC that psu only has 2 pci-e connectors which means he will have to use molex-to-pci-e connectors, guru3d states that 2 gtx460 uses 433w on full load so the sapphire 625w should be plenty enough(£20 cheaper and has 4 pci-e connectors).
he should be looking to overclock the t.i.t.s off his i5 along with his SLI. 625w might be cutting it a bit thin. i wouldnt want to overdraw from a £50 psu, dont care whos its made by and how good value it is. if a £123 850w xfx/seasonic psu can go boom then this could aswell maybe easier.
well if thats the way you think then why didnt you just spec the xfx 750w black edition for £10 more so he can "overclock the t.i.t.s off his i5 and his sli". the xfx psu has 4 pci-e connectors which prevents him from using molex to pci-e connectors.
the xfx 750w core edition isnt modular and its an extra 10er. NICE 1
how much is a converter £2 ? for crying out loud.
well for 50 more watts and less hassle of using converters(tidier apparatus) i guess its worth to get the xfx black edition.
LOL less hassle? its putting a lead on the end of another lead. its like putting the top back on your pen. if anything its making his leads a little longer to route anyway he wants which is better.
if he wants to pay an extra £21 so he doesnt have to buy a £2 converter and for an extra 50W ontop of 700W which is already enuff then be my guest. but youll have to wait because they are OUT OF STOCK.
all this for a ****ing £2 converter wots your ****ing problem.
Jony you never ****ing fail do you. your giving Limavady a bad name.
when i tryed to post it said "you have been BANNED" "this BAN will lift on the **/**/**
are you going to argue with wot the forum said now?
can a mod ban Jony for 10mins to show him wot it says. thanks
Jake, as in other post, calm down
I dont know why you get abusive all the time
People are allowed differing opinions, stop trying to force yours on everyone and getting angry when you cant
OcUK Value GeForce GTX 470 1280MB GDDR5 PCI-Express Graphics Card with MAFIA 2 £211.49
(£179.99) £211.49
(£179.99)
Intel Core i5 760 2.80GHz (Lynnfield) (Socket LGA1156) - Retail £149.99
(£127.65) £149.99
(£127.65)
Microsoft Windows 7 Home Premium - Retail (Full Version)(GFC-00025) £113.96
(£96.99) £113.96
(£96.99)
MSI P55A-G55 Intel P55 (Socket 1156) DDR3 Motherboard £84.99
(£72.33) £84.99
(£72.33)
Corsair XMS3 4GB (2x2GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (CMX4GX3M2A1600C9) £70.49
(£59.99) £70.49
(£59.99)
Coolermaster Storm Scout Gaming Case - Black £66.99
(£57.01) £66.99
(£57.01)
Sapphire Pure 625W Modular Power Supply £49.98
(£42.54) £49.98
(£42.54)
Samsung SpinPoint F3 1TB SATA-II 32MB Cache - OEM (HD103SJ) £42.99
(£36.59) £42.99
(£36.59)
Titan Fenrir Evo CPU Cooler (Socket LGA775/LGA1156/LGA1366/AMD K8/AM2/AM2+/AM3) £35.99
(£30.63) £35.99
(£30.63)
Samsung SH-S223C/BEBE 22x DVD±RW SATA ReWriter (Black) - OEM £13.99
(£11.91) £13.99
(£11.91)
Akasa 8-Pin 30cm PSU Extension Cable £4.69
(£3.99) £4.69
(£3.99)
Sub Total : £719.62
Shipping cost assumes delivery to UK Mainland with:
DPD Next Day Parcel
(This can be changed during checkout) Shipping : £12.50
VAT is being charged at 17.50% VAT : £128.12
Total : £860.24
im not sure about torrenting windows 7 so here ya go a little over budget but i can go over (ill try) about the i3 build i actually had cornflakes :)
i have no problem agreeing with other ppls opinions and debating mine with me, ive done it plenty of times on here. im civil up until ppl start to take the **** over a £2 converter.
That build looks good too, but as I said before so did your earlier one, youve gone from a 5850 to a 470 which whilst slightly better the difference is negligible, comparison and a Phenom 955 to i5 760 which again when it comes to gaming the difference is again negligible (except in FC2), comparison (linked bench compares 750 not 760 as 760 does not have full range of scores)
Either set up will be good
It wasnt me he was getting arsey with, it was Jony, and I dont think Jony pointing out the subtle differences between whether you were banned or suspended warrant getting irate over, personally, its a matter of semantics
