I don't see the problem with using BCE/CE it is more fitting to history and pre-history.
Because BC/AD are religious terms? And has no place in any kind of objective academic study?
Heh. There was history prior to Christ's birth*, you know?
*Delete if offended.
yes but as we all know only about 4000 years of it.....
It says that the world cannot be moved, but doesn't state which "world" that is. A lot of passages use "world" to mean, essentially, the Middle East
Fear of change is a sign of cowardice.
And blind acceptance of change without due consideration is retardation.
Do you have any idea what cowardice actually means, or are you simply using it as a power word to appear clever? To be a coward is to seek the preservation of ones life, at any cost. Morality, logic and reason are all discarded in the rat race to save ones own agenda. The zombie-esque scenario of people clambering over other people to get the last few boats is the epitome definition of what cowardice represents.
The Fear of change (which we are ALL, instinctually, subjected to) has no place in this thread. If the change was revolutionary, introducing wholly new concepts into historical chronological marking, then so be it. But, as it, is, it is little more than politically correct re-branding. Changing accident, to incident, or christmas, to xmas.
Implying those who disagree with the change are either fearful, or cowards is grossly inept.
It was before protestantism exisited. There was only catholicism back then, with anything else punishable by death for heresy. You're probably thinking of the Gregorian modification of the calendar, which happened when England was a Christian country with an Anglican monarch, but that was just an update to the existing Christian calendar to improve accuracy.
I don't care if people advocate changing the numbering of the years to something areligious because they don't want a religious calendar.
I don't care if people advocate keeping the current religious numbering of the years because so many people are so used to it.
I do care a bit about people advocating using a religious calendar and having everyone pretend it isn't a religious calendar. It's a dishonest position.
