Because they know what their on about and no offence to the op but from his post there seems to be a bit of ifs and buts in his knowledge
I wasnt quesitioning i was just trying to further my knowledge. tbh "because" isnt an explanation...
It don't work like that here, An electrician may well b-able to do the job for something close to £300, To have a totally separate supply put in you are talking thousands.
Not linked to anything in particular with this thread but:
My mate rents a garage about 5 minutes drive from his house. It has no toilet facilities and so he makes do with a bottle....
/Completed unrelated post over.
I'm confused, why do you not just link it up to your house supply. That's what we have done and we have a triple garage with a two bedroom summerhouse built above it all connected to our main house supply with a separate junction box in the garage.
Do you have any idea how much that would cost?
OP
You really don't seem to know what you are actually doing, Please don't play with electricity, Contact an electrician please.
/thread
I actualy use this at the moment. Wouldnt mind a Permanent light though.Whoa, You could tell I was in a rush when I wrote that OP.
My garage is not next to the house, I live in a semi detached house, my neighbour to my right has his garage with mine attached to the other side.
He's allowed me to use his power supply if I pay for it. I know if he moves or I move I will have to stop what Im doing.
Neither is mine, my garage is some distance from my house, I had an electrician lay the cable from my house to the garage and fit the lot. You can't take the supply from your neighbour it is illegal.
Seen the layout now and I'd suggest digging a trench and laying some armoured cable from your own house, through your neighbours back garden and to your garage
If it were me and i was on friendly terms with the neighbour then i would buy a reel of armoured cable, run it away from your building into your back garden, then run it round the back fences through his garden, then back towards your garage building.
Without seeing a diagram of the way the plots are set out i am not sure if this is possible, but it is the route i would go. Ie, the cable would cross his land, but not actually be attached to any of his buildings and would stay right out of the way around the back of the plots.
My Gaff is a bit of a joke, there is a bit of Twin and earth dangling from the corner of the eaves of the house to the corner of the eaves of the garage.
Been like it 37 years![]()
