- 18 May 2010
Just ordered some from OCUK to go with my new cooler thanks for the information posted
You all won't be disappointed, why not order now for your superb mx4You won't be disappointed
mx4 is also non conductive and has no cure time before working optimally.
I caved in and got some this morning. It best be bloody good.
How did it go with your new mx4 ?
I need a mobo first which is being delivered tomorrow thanks to rjkoneill![]()
I had pick the right mx4 thanks to rjkoneill
What the hell is "tinting" all about! On Arctics web site it doesnt have an application specifcally for the MX-4 so I was reading another one and it says to "tint" using a card and then apply a small amount in the centre, thats the first time i've ever heard of that method
just put a small sized pea in the centre and attached the air cooler as it will spread out itself. That's what I did and got excellent lower temp on my 4.3ghz around 72C max !!!
Ordered a tube of this yesterday
Hopefully it lives up to the hype
If not, I'm coming after you bulldog~!
thats what i would suggest too
what vcore do you use for 4.3 on your core i7 bulldog?
is there much difference between what you set in bios and what cpuz reads?
