- 25 Sep 2009
- Billericay, UK
I wonder how much margin Nvidia can cut from the GTX480 before it starts to lose money?
Just talked to my friend, and apparently his costs for the 6850 and 6870 are:
6850 @ £119.67
6870 @ £154.42
That of course is ex vat, and shop markup.
Sapphire cards.
So looking at ~£200 for the 6870 as predicted![]()
Yea, but would you take a 6870 over a GTX470 with both at same price, knowing that GTX470 will deliver better tessellation performance and similiar performance in other areas, plus with more games favour Nvidia than ATI/AMD? Not trying to start a fight or anything here, just speaking from analytical point of view and for discussion sake.Tessellation aside, it's not at all disappointing.
It's the same price as the 5850 was on release, is almost as fast as a 5870 and has only 1120 shader cores to the 5870s 1600. Very good efficiency improvements to an already efficient architecture buy the looks of it.
The 6870 is aimed at the GTX 460, so comparing it to a model which is much higher up the product 'food chain' is a tad pointless.
If you don't mind the additional heat, noise, power consumption and marginally higher price for better performance in a feature which isn't utilised much, then yes, you would get the GTX 470.
It's aimed at GTX460 1GB because AMD says so? Even when the price of GTX460 1GB is at £150ish, when the 6870 is most likely going to be at just under £200...which is actually GTX470 price?The 6870 is aimed at the GTX 460, so comparing it to a model which is much higher up the product 'food chain' is a tad pointless.
The 6870 HAS to be priced at less than £195. The closer to 1gb 460 prices the better.
If it isn't, which the prices posted so far seem to confirm, then what's the point in buying one with 5850's available for £192, or the 470 for £200.
