Asus GTX480 EK backplate
my asus 480 has an ek backplate on
so does this one we sell
it does fit, the asus is a reference design card :)
Well I have no idea why elswhere they told me it doesn't fit.
Thaks mate - I bought one from OCUK - unfortunately nikel one as they have no balack ones.
elsewhere obviously have no idea what they are talking about. there is hardly any 480s that have strayed from reference design.
the nickel ones look better than the black imho
i swapped mine out with a friend and it looks amazing :D
huh, I called EK today, and they said that I have to use backplate with washers, and they will send me them.Well, BTW I took it off and now I'm waiting for washers.
I found another strange thing with my card - memory at the front of my card don't touch water block at all, no contact between them, when OCing I can see artirfacts only :P, I have no idea that this is because my card is baended without backplate or not.Maybe water block it is not stright , is banded or whatever?
Reset the overclock do you still get artifacts?
