- 4 Dec 2008
I know that EK one doesn't fit Asus cards, but the question is - is there any backplate to install with this card and EK FC water block?
my asus 480 has an ek backplate on
it does fit, the asus is a reference design card![]()
huh, I called EK today, and they said that I have to use backplate with washers, and they will send me them.Well, BTW I took it off and now I'm waiting for washers.
I found another strange thing with my card - memory at the front of my card don't touch water block at all, no contact between them, when OCing I can see artirfacts only, I have no idea that this is because my card is baended without backplate or not.Maybe water block it is not stright , is banded or whatever?
Hi guys I've seen a lot of memory with these red heat sinks are they a custom add-on
They look good
Cheers
They look good
Cheers
So guys what do u think - can I damage my card memory withour proper cooling?
Should I worried?
