.Was just looking over at XDA and theres finally some really nice roms out, I'm going to try out Darky's Raw Steel Edition tomorrow, just wanted to share with you guys.
Install via ClockworkMod Recovery and a full ROM.links for the best and most stable and how do you install these , just flash there rom over the top of the original 2.2 ? or is it a full rom you flash?
The Froyo upgrade will be available in the UK from early November and we expect all operator versions to be available by the end of November
http://forum.xda-developers.com/showthread.php?t=814091
Btw, > http://twitter.com/samsungukmobile
Just had my phone replaced with a new one and this time the GPS works but I am beginning to think if I should have even bothered because the GPS is real bad. Updates too slow and takes ages to get a lock.
yeah I was going to flash it myself but I don't really want to risk it, I don't mind waiting for Froyo even if it does take ages.
How safe is it to root the phone, and is it easy to get back to 'stock' if anything happens?
When rooting the phone, what roms give you 2.2? or is this just a download i can do after rooting it?.
Things have moved on a bit since the OCLF, it's really more suited to 2.1 I find. The OCLF ext2 loop cheats with the quadrant scores as wellI used Ryanza lag fix and it worked like a charm and my 2.2 was done with the kies reg hack....unrooting it is just a click away.
