I bet they pulled it.
I think they will keep it up for an hour and then hide it.
OcUK had the 6870 up for £199.99 before they pulled it earlier.
didn't see any comparisons vs a 5850 though ?
and what happens to comparison when 5850 is overclocked ?
I'm tempted with a 6870, 5850 or 470 - but not sure which yet
Prices can be adjusted at any time
We got reviews going up tomorrow morning of both cards courtesy of helios1234 will drop the link by here when they are onlinedidn't see any comparisons vs a 5850 though ?
The new AMD Catalyst A.I. options can be found by opening the 3D settings page, selecting the “All” tab and scrolling down. The Texture Filtering Quality slider has three settings – High Quality, Quality (default), and Performance. The High Quality setting disables all texture optimizations. The Quality setting enables a trilinear optimization as well as an anisotropic sample optimization, which are designed to have no visible impact on image quality while offering improved performance.
Radeon HD 6850 and 6870The Performance setting enables more aggressive versions of these optimizations that offer further performance improvement, but may have a small impact on image quality. The AMD Radeon HD 6800 series continues to support fully angle invariant anisotropic filtering, and incorporates further improvements in LOD precision relative to the ATI Radeon HD 5000 Series.
These image quality benefits come with no additional performance cost and remain enabled at all Texture Filtering Quality settings. Here at Guru3D when comparing performance and image quality against NVIDIA products, we use the same Texture Filtering Quality setting in the NVIDIA Control Panel to ensure the most direct and fair comparison.
However, as of this writing NVIDIA products do not offer a comparable anisotropic filtering option with full angle independence. The Surface Format Optimization checkbox allows improved performance in selected games that use 16-bit floating point surfaces for HDR rendering. It is designed to have no discernable effect on image quality, and therefore we recommend it be left enabled as your default.
We got reviews going up tomorrow morning of both cards courtesy of helios1234 will drop the link by here when they are online![]()
I would still go for the 470
Same here, got a budget of about £220.00 for a new card.thanks - was leaning that way too but awaiting a load more reviews of the 6870 - early days yet![]()
