World Of Warcraft
The link that ThundyCat provided got me to 97% and 5.19GB out of 5.29GB
I will check it again in the morning, But how do i fix this problem, because its only going to happen again when another patch is realeased
yh dude i got the cpu block thanks :-)
Just going give it a clean, Still going be a while before i get it all done need save for the 480 :S
The installer Tome.MPQ is the last 100Mb you need.
Head over to here: http://www.wowwiki.com/Patch_mirrors
You want: 3.3.x → 4.0.1.12911 Final Stage-4 (~72 MiB)
Pick any of the EU PC mirrors. It may take a couple to find one that gives you decent speeds/you can download without queueing, and so on. I found the sourcearchive one to be extremely quick just now.
Once you have the zip, close the blizzard updater, extract it into the update folder in WoW and start the updater again, it shouldn't need anything else.
Plus, the patch includes a new updater that works differently, so hopefully the problem you're having won't stick around with the new patcher. Because after this patch there's another 1.6Gb patch, and that isn't available as a seperate download yet, it has to be done through their new patcher. Good luck! :D
Personally, the first thing I would do is uncheck the port options in your virtual servers tab of the router setup.
I've downloaded part 4 and now using the updater within it to update and other things, I think its the 1.6Gb patch which you speak about.
Thanks iviv
Mate that's strange, I downloaded the WoW client and got the new cataclysm downloader, rather than the old wotlk one. Doubt there's much difference in download speeds between the two tho
It may change matey after this 1.6Gb patch i am downloading now
It won't make a difference to downloading files of the Internet.
If your updating files through you WoW client now, and it's working, then it was a strange problem indeed.
I know have the official downloader back up, This time its the Cataclysm one.
Still saying tracking is not responding but i am downloading at 575 KB/s
8.40Gb of 9.81Gb
The WoW downloader uses the bittorrent protocol, so setting up port forwarding in virtual servers is pretty much a requirement for it to work reliably.
If he's turned peer-to-peer downloads off though it doesn't really matter.
Yes.
Peer to Peer seems to drain your bandwidth more, so I never use it now.
Note: I'm actually not 100% sure this is the case, I use Vuze to download some stuff via torrents and have no problems whatsoever, so I think the WoW launchers Peer-to-peer technology is dodgy.
OK so ive downloaded everything, WOW is all up to date, Just activated my account and go to login but i says "Logging into game server" When i click on my realm and i cant play :(
I will post some screen shots up showing you
This is what i get after i have
logged in
Chosen my realm (Mazrigos)
I have tryed others but they all do the same thing
