Do not worry about the warranty as the stock GTX480 HSF just pulls off no seals to break on my Asus.
First thing I did when I got mine 6 months ago was remove the HFS & clean the GPU paste as there is way to much on there. Then I put on some AS5 & the temps went down 7-9C immediately.
Since then I bought a Gelid Icy VGA cooler and mine now idles @ 43C. Under full load its under 70C @ all times + also silent @ all times. The stock HSF is unsuitable for temps due to it being a very poor design. 3rd part HSF's show you how much when they reduce temps by over 20C you know something is wrong with the stock Nvidia design
If you can find them buy some Gelic Icy or Zalman VF3000 for GTX480. Either will be silent & offer more overclocking headroom (not that you will need it.........).
