Let me know if you find a decent password or bookmark manager, I'm still using Xmarks which it set to stop working in Jan.
Also, check out the adblock.ini file in Iron, it allows you to blacklist ads without any extensions, just plop the url you want to block in adblock.ini
Alternatively, you could just download Fanboy's block list and put it in your iron directory:
https://secure.fanboy.co.nz/iron/complete/adblock.ini
Easy, simple and works well I find.
