No, I did not buy 5. Must have been somebody else (or several somebodies).
I was just kidding mate.
Do you lack the ability to post anything useful?
I did use the search engine anyway, hence me saying I only found it at £430 ...95% of the time I can find what I'm after within seconds just by searching, this time I couldn't find it within a couple of minutes so I just asked. Simple.
DotA, I sent you a trust message with the info you want.
I managed to find another one better spec'd then the Toshiba.
How does this look:
Acer TravelMate
Intel® ULV Core 2 Duo (ULV SU9400, 3 MB L2 cache, 1.4GHz, 800MHz FSB)
13.3" (Acer CineCrystal, 1366x768 HD, High Brightness, LED Backlit)
Win Vista (will be upgrading to Win 7 Ultimate 64)
4GB (DDR3 1066MHZ)
320GB
ATI Mobility Radeon HD 4330 with 512MB Dedicated RAM
5-in-1 card reader (SD//MS/MS-Pro/MMC/xD-Picture card™)
3x USB 2.0 ports
Kensington lock slot
8 Hrs+ Battery Life
1.6Kg
Price: £330 delivered
Hopefully I get it sometime this week!![]()
I have this laptop, and I believe I paid almost twice that about 6 months ago! Ace little laptop, 7 doesn't like the fingerprint reader though (if it's the same one that I'm thinking about TM 8371?)
But either way, same specs as mine, does play HL2 engine based games, but oftern goes a little loopy when stuff is going on, i.e. L4D2, when you get a tank whilst there is a rampage going on it usually craps out, or TF2 where there is a lot of battle going on... But it handles WoW perfectly in full screen under "Good" graphics, ditto for HD video - as all I watch these days is 720p TV shows.
Just ordered, the website which is selling it for 350 also has a voucher code for 2.5 percent off if anyone wants to search for it, or PM me.![]()
I am getting more and MORE tempted to order a second one, with a 120GB SSD drive.
Ok I'm gonna email you, just incase...![]()
edit: Can't PM you and your trust isn't enabled, email me please!![]()
Now bought one, hopefully arriving later this week. My first laptop!
it slots straight in! Total price for laptop plus SSD was £440. Win7 bootup is much quicker now, currently installing updates but I will check under the battery in a short while to see if theres a sim slot.
Wow that is a great price, definately would have had second thoughts over my £550 HP 2310ea but I guess my i3 processor and dvd writer makes up for it, and Win 7 license.
Just installed a 64GB Crucial C300 SSD in mineit slots straight in! Total price for laptop plus SSD was £440. Win7 bootup is much quicker now, currently installing updates but I will check under the battery in a short while to see if theres a sim slot.
64gb probably isnt enough for me though unfortunately with all the files i have!Wow that is a great price, definately would have had second thoughts over my £550 HP 2310ea but I guess my i3 processor and dvd writer makes up for it, and Win 7 license.
It certainly is very nippy and the SSD has given it a nice boost.
