Whichever way you look at it -
Sorry for the confusion... I just didn't really switch on to the fact you were using a 2407WFP - the responsiveness of the EW2420 is similar. The reason I recommended the B2430L is because you mentioned you would be playing games such as CoD Black Ops - personally I wouldn't be comfortable playing that kind of title on a *VA panel but that's just me.Whichever way you look at it -
- The EW2420 has better contrast than the 2407WFP and B2430L
- The EW2420 has better colour reproduction than the B2430L and is perhaps closer to the 2407WFP (the latter being broad gamut but the semi-gloss screen on the EW2420 seems to bring things a bit closer visually)
- The EW2420 has comparable if not slightly better responsiveness than the 2407WFP but the B2430L is better than either of these:
Dell 2407WFP![]()
BenQ EW2420
The first image if from the TFT Central review with the 'worst case' 2407WFP responsiveness on the right. The second image is one captured from my EW2420 for the worst case scenario. Despite the images looking different due to the size and colour differences (different camera, different monitor etc.) the responsiveness based on this test is comparable if not in the EW2420's favour.
whats the name of that test?
In terms of what? Responsiveness? Yes. In terms of everything else, as covered in this thread, it would be a large upgrade. Is that monitor still working so you could test PixPerAn or not?
Haha. Yeah blacks on this thing really are excellent (as they often are on Vertical Alignment panels). If you go on 'Streaky Pictures' by pressing F6 it should have a car moving along at the fastest 'tempo' (16 I believe). If you take a picture of that with a camera at the highest ISO (actually 200-400 should be fine) that should do the trick. It's difficult to see the extent of the trailing just by looking so the camera bit really helps.![]()
Oh dear... Yeah half of the problem with this responsiveness malarky is that once you've noticed it you keep on looking for it obsessively. The PixPerAn car chase test doesn't necessarily capture this but lighter objects (especially white) moving against a darker background can leave 'black ghosting' that is usually not found on a TN panel. I think this can best be explained by an example - using a thermal sight in Armed Assault 2: Operation Arrowhead and moving the mouse at a fast pace towards the left or right:
You can see it (ghostly figure on left) has displaced impressively far from the actual image (white man on right). If the mouse is moved more slowly then it doesn't displace as far but it's still there.
If you move your mouse at a moderate pace against the dark blue background of overclockers as you type a post do you notice a strange black ghost image or just white-grey trails?
You could try the ghosting test at Lagom: http://www.lagom.nl/lcd-test/response_time.php#response_time_advi like that test with the guy you did and the vision mode, is there anything online i can try which is like that?
Ack, that would be so off putting. Though I guess like you say, unless you're always looking out for it, you probably won't notice it all the time.Yes it was.
