Online tape measure?
3 Jan 2009
Anyone know if there's a site that takes your screen size (diagonal, inches) and resolution and then brings up an image of a tape measure/ruler on your screen, to perfect scale?
Incorrectly saw mine as 16:10, changed to 16:9 and it was accurate.
Got some weird looks measuring it with my steel tape, in the office though :D
Doesn't work for me... Comes out with 24cm on screen being 30cm of real ruler.
It got the resolution right, but I think it got the screen dimensions wrong. I'll go find a tape measure to check the diagonal and report back.
Why oh why would you want such a thing? I mean honnestly what posible use could it be?
Get up, go to shop, by tape measure or rule and measure what ever you need to accurately without scratching your lovely monitor.
It might guess your resolution easily enough, but pixel pitch, it has no idea. And thats the most important one.
Was correct resolution on mine, but wrong sizes.
