Drinking recepticles, and is my mate retarded?
Sounds incredibly pedantic, fussy and very odd personality type.
In other words he'd probably fit right in here, what's his username going to be? :p
I hope you relentlessly gave him **** for doing it at the time. I only drink Champagne off strippers anyway, Champagne glasses? No
Are some glasses designed for the beer though? I thought some had a certain base that effects the head etc?
"Lager" glasses are cut at the bottom to keep the drink bubbly :)
I dont care what my alcohol comes in to be honest as long as its clean
It's just like you're describing yourself. :p
Really does sound like he's being a bit of a tool for the sake of it though, sure it might be slightly better served in the correct receptacle but for most situations the difference is negligible, with Stella that goes double.
Since when has Stella been expensive? I don't know of any Pubs that sell it for more than the other on tap largers...:confused:
Worst "I have problems, but I'm saying it's a friend to shift focus and to gauge a reaction from teh internetz" thread.
In seriousness.. He sounds like a *******.
