if you're struggling with getting put forward by an agency you need to work on the key words etc in your CV. The ideal situation is to get an agent working for you, if they think there's a chance of placing you they'll do their best because obv that means they get commission, but you'll only get there by making yourself known. Once you've gone a reasonable distance with one job you'll usually be considered for any others that come up.
