anything is better than a 106. a soggy old bmw isnt better than anything. you'll buy one, it'll loose all its water then the headgasket will fail blah blah. it will cost you more in time, parts and effort to fix than sorting out a newer simpler car.get that bmw is better than other cars thing out of your head, for the money you have you wont be able to buy a reliable one.
diamond mark found you a 2L non turbo for £600 with a full years mot, that is what you need when you have to buy a cheap car, you can not afford to be fussy, so be sensible.. as so far you are not.
My bad, crack on son and enjoy the purchase
