£30/40 not see it that cheapWD Scorpio Black would be your best bet. Can pick one up for around 30-40quid depending on where you go.
http://www.overclockers.co.uk/showproduct.php?prodid=HD-352-WD&groupid=1657&catid=1660&subcat=1667
Sadly they are out of stock...
I believe they're about the same, if not a little slower. The ones you might be thinking of are the MomentusXT ones (the ones which are basically hybrid drives with a small SSD).
